Does anyone know what brackets work to change from drums in the rear over to calibers or where i can get them from?
Most of all the suppliers you will find use a GM rotor, here's one site, '86 & Later Toyota Truck, Downey used to make a kit also , I believe it is the same one found on LC,s site. The GM rotors have a smaller center hole so that must be machined ,why I went with a SVO Mustang rotor, had to make my own brackets ,as the offset Ford to Chevy is different! Do a search for rear disk conversion & you will get a lot of info!
