Marla to Gaj Calculator – Quick & Accurate Land Measurement Tool for Everyone
Discussion in 'Off Topic' started by The Smartkey Realty, Nov 27, 2025.
  1. The Smartkey Realty
    The Smartkey Realty Newbie
    If you’re dealing with land measurements in North India, you’ve probably come across the terms Marla and Gaj (also known as square yards). Converting between the two can be confusing because the value of a Marla often varies from region to region.
    To make things easier, here’s a simple Marla to Gaj Calculator you can use anytime:
    Standard Conversion
    • 1 Marla = 30.25 Gaj (Common in Punjab & Haryana)
    • 1 Marla = 25 Gaj (Traditional measurement in some regions)
    How to Use the Conversion
    • Multiply the number of Marlas by 30.25 or 25 based on your region.
    • Example:
      • 5 Marla (standard) = 5 × 30.25 = 151.25 Gaj
      • 5 Marla (traditional) = 5 × 25 = 125 Gaj
    Why a Marla to Gaj Calculator Helps
    • Saves time during property buying/selling
    • Helps avoid errors in manual calculation
    • Useful for brokers, investors, and homeowners
    • Makes regional variations easier to understand
