Raised bed floor
Discussion in 'Suspension/Chassis' started by Suthrn98, Jul 25, 2011.
  1. Suthrn98
    Suthrn98 Member
    I am not sure this is where this belongs, but it's a question i have come across during the bag and bodydrop process. I want my bed to be stock, but raise the floor up. I want to be able to use my bed floor for my motorcycle or whatever I need to use the bed for.
    I know how I'm going to raise it, but my concern is how to mount it after I have raised it. I have an idea in mind, that will still use all 8 mounts, but wanted some of your guys ideas. Thanks.
  2. jetas
    Make the mounts taller. Or make spacers
  3. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Pretty much use a piece of round metal weld it to the bed then weld a piece of flat to the open bottom of the piece of round with a bolt welded to it
  4. jeremystephens
    jeremystephens Enthusiast
    mississippi
    94 xcab
    ive seen and done a few where we use some good size tubing then weld a fender washer and then just get some long bolts
  5. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    yeah i wouldn't recommend welding the spacer to the bed, it'll make it crack eventually.
    the long bolt idea will work. i personally did a tube that had the stock bed bolt welded to a thick washer, then that was welded to the tubing making it a stud that screws into the bed. then on the opposite side of tube i welded a nut to a thick washer and used that to bolt to stock mounts. bolting it on both sides will allow it to flex and not crack anything.
    i hauled a 86 kawaisaki 750 using em, and also a 2jz motor and trans without problems
